Delete a license
DELETE /cluster/licensing/licenses/{name}
Deletes a license.
Related ONTAP commands
system license delete
Learn more
name |
string |
path |
True |
serial_number |
string |
query |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
525028 |
Error during volume limit check, cannot remove license |
525029 |
Current volume use will exceed limits if license is removed |
1115137 |
Cluster license requires a base license to be installed |
1115144 |
Cloud licenses cannot be deleted |
1115178 |
A tier license that is still in use cannot be deleted |
1115213 |
License is still in use and cannot be removed |
1115406 |
Capacity pool licenses cannot be deleted |
66846823 |
A FlexCache license that is still in use cannot be deleted |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
