      Delete a schedule
DELETE /cluster/schedules/{uuid}
Deletes a schedule.
Learn more
uuid  |
string  |
path  |
True  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
459758  |
Cannot delete a job schedule that is in use. Remove all references to the schedule, and then try to delete again.  |
459761  |
Schedule cannot be deleted on this cluster because it is replicated from the remote cluster.  |
459762  |
The schedule cannot be deleted because it is a system-level schedule.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
