Delete a software package from the cluster
DELETE /cluster/software/packages/{version}
Deletes a software package from the cluster. The delete operation fails if the package is currently installed.
Related ONTAP commands
cluster image package delete
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
version |
string |
path |
True |
Status: 202, Accepted
Status: Default
ONTAP error response codes
| Error codes | Description |
10551315 |
Package store is empty |
10551322 |
Error in retrieving package cleanup status |
10551323 |
Error in cleaning up package information on a node |
10551324 |
Error in cleaning up package information on multiple nodes |
10551325 |
Package does not exist on the system |
10551326 |
Error in deleting older package cleanup tasks. Clean up images from the store and retry |
10551346 |
Package delete failed since a validation is in progress |
10551347 |
Package delete failed since an update is in progress |
10551367 |
A package synchronization is in progress |
10551388 |
Package delete operation timed out |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
