      Delete a broadcast domain
DELETE /network/ethernet/broadcast-domains/{uuid}
Deletes a broadcast domain.
Related ONTAP commands
network port broadcast-domain delete
Learn more
uuid  |
string  |
path  |
True  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967103  |
A broadcast domain with ports cannot be deleted.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
