Delete http proxy configuration for an SVM or cluster IPspace
DELETE /network/http-proxy/{uuid}
Deletes the HTTP proxy configuration of the specified SVM or Cluster IPspace.
Related ONTAP commands
vserver http-proxy delete
Learn more
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
