Deletes a cifs home directory search path
learn more
doc /protocols/cifs/home-directory/search-paths](#docs-nas-protocols_cifs_home-directory_search-paths)
DELETE /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Deletes a CIFS home directory search path.
Related ONTAP commands
cifs server home-directory search-path remove
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
index |
integer |
path |
True |
Home directory search path index |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
