      Delete a specific FPolicy event configuration for an SVM
DELETE /protocols/fpolicy/{svm.uuid}/events/{name}
Deletes a specific FPolicy event configuration for an SVM. A cluster-level FPolicy event configuration cannot be modified for a data SVM through REST. An FPolicy event that is attached to an FPolicy policy cannot be deleted.
Related ONTAP commands
fpolicy policy event delete
Learn more
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
name  |
string  |
path  |
True  |
Status: 200, Ok
Status: Default
| Error Code | Description |
9764874  |
The FPolicy event is a cluster event  |
9764947  |
The FPolicy event is attached to an FPolicy policy  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
