REST API reference
Deletes a kerberos realm
  • [doc /protocols/nfs/kerberos/realms](#docs-nas-protocols_nfs_kerberos_realms)
DELETE /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Deletes a Kerberos realm.
  • vserver nfs kerberos realm delete
svm.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
1966125
Failed to remove hosts entry.
1966126
Failed to lookup hosts entry.
2949141
Failed to lookup Kerberos realm.
2949142
Failed to remove Kerberos realm.
3276942
Service principal name is invalid. It must of the format:"nfs/@REALM\\\"
3276976
"realm" is a required input
3276998
Only the data Vservers can own NFS Kerberos realms.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
