Remove an NVMe subsystem
DELETE /protocols/nvme/subsystems/{uuid}
Removes an NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem delete
Learn more
uuid |
string |
path |
True |
allow_delete_while_mapped |
boolean |
query |
False |
allow_delete_with_hosts |
boolean |
query |
False |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
72090023 |
The NVMe subsystem contains one or more mapped namespaces. Use the |
72090024 |
The NVMe subsystem contains one or more NVMe hosts. Use the |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
