Delete a data SVM configured as a tunnel
DELETE /security/authentication/cluster/ad-proxy
Deletes the data SVM configured as a tunnel for Active Directory-based authentication for cluster user accounts.
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
