Delete a SAML service provider configuration
DELETE /security/authentication/cluster/saml-sp
Deletes a SAML service provider configuration.
Learn more
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320803 |
SAML must be disabled before the configuration can be removed. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
