Delete key managers
DELETE /security/key-managers/{uuid}
Deletes a key manager.
Related ONTAP commands
security key-manager external disable -
security key-manager onboard disable
Learn more
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536208 |
Failed to delete the SVM Key ID. |
65536233 |
Internal error. Deletion of km_wrapped_kdb key database has failed for onboard key management. |
65536234 |
Internal error. Deletion of cluster_kdb key database has failed for onboard key management. |
65536239 |
Encrypted volumes are found for the SVM. |
65536242 |
One or more Storage Encryption devices are assigned an authentication key. |
65536242 |
65536800 |
Failed to lookup onboard keys. |
65536813 |
Encrypted kernel core files found. |
65536817 |
Failed to determine if key manager is safe to disable. |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536827 |
Failed to determine if the SVM has any encrypted volumes. |
65536828 |
External key management is not enabled for the SVM. |
65536867 |
196608301 |
Failed to determine the type of encryption. |
196608305 |
NAE aggregates are found in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
