Aborts an ongoing ebr operation
learn more
doc /storage/snaplock/event-retention/operations](#docs-snaplock-storage_snaplock_event-retention_operations)
DELETE /storage/snaplock/event-retention/operations/{id}
Aborts an ongoing EBR operation.
Related ONTAP commands
snaplock event-retention abort
id |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090541 |
A completed or failed operation cannot be aborted |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
