REST API reference
Aborts the ongoing legal-hold operation an abort does not rollback any changes already made you must re-run begin or end for cleanup
example
<br/>
delete "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1?lh_operationid=16908292"
<br/> # learn more * [doc /storage/snaplock/litigations/{litigationid}/operations](#docs-snaplock-storage_snaplock_litigations_{litigationid}_operations)
DELETE /storage/snaplock/litigations/{litigation.id}/operations/{id}
Aborts the ongoing legal-hold operation. An abort does not rollback any changes already made. You must re-run begin or end for cleanup.
  • snaplock legal-hold abort
Example
DELETE "/api/storage/snaplock/litigations/f8a67b60-4461-11e9-b327-0050568ebef5:l1?lh_operation.id=16908292"
litigation.id
string
path
True
id
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090541
A completed or failed operation cannot be aborted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
