Delete an SNMP traphost
DELETE /support/snmp/traphosts/{host}
Deletes an SNMP traphost.
Learn more
host |
string |
path |
True |
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9043970 |
Traphost entry does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
