Delete an SNMP user
DELETE /support/snmp/users/{engine_id}/{name}
Deletes an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
Related ONTAP commands
security login delete -
system snmp community delete
Learn more
engine_id |
string |
path |
True |
Engine ID of owning SVM or remote switch. |
name |
string |
path |
True |
SNMP user name. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621475 |
This operation is not allowed on a node SVM. |
2621699 |
This operation is not allowed on a system SVM. |
5636123 |
Cannot create an SNMP user with a role other than readonly, none, or admin. |
5636124 |
Cannot create an SNMP user with a role other than vsadmin-readonly, none, or vsadmin. |
5832712 |
Cannot modify attributes for user "diag." |
7077906 |
Cannot use given role with this SVM because a role with that name has not been defined for the SVM. |
9043999 |
ONTAP failed to create an SNMPv3 user because SNMPv3 is disabled in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
