Retrieve application components
GET /application/applications/{application.uuid}/components
Retrieves application components.
Overview
The application component object exposes how to access an application. Most application interfaces abstract away the underlying ONTAP storage elements, but this interface exposes what is necessary to connect to and uses the storage that is provisioned for an application. See the application component model for a detailed description of each property.
Query examples
Queries are limited on this API. Most of the details are nested under the nfs_access, cifs_access, or san_access properties, but those properties do not support queries, and properties nested under those properties cannot be requested individually in the current release.
The following query returns all application components with names beginning in secondary.
GET /application/applications/{application.uuid}/components?name=secondary*
The following query returns all application components at the extreme storage service.
GET /application/applications/{application.uuid}/components?storage_service.name=extreme
Learn more
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
query |
False |
Filter by UUID |
name |
string |
query |
False |
Filter by name |
storage_service.name |
string |
query |
False |
Filter by storage_service.name |
storage_service.uuid |
string |
query |
False |
Filter by storage_service.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[application_component] |
"next": {
"href": "/api/resourcelink"
"records": [
"application": {
"name": "string",
"uuid": "string"
"backing_storage": {
"luns": [
"creation_timestamp": "string",
"path": "string",
"size": 0,
"uuid": "string"
"namespaces": [
"name": "string",
"size": 0,
"uuid": "string"
"volumes": [
"name": "string",
"size": 0,
"uuid": "string"
"cifs_access": [
"type": "string",
"uuid": "string"
"ips": [
"string"
"path": "string",
"permissions": [
"access": "string",
"user_or_group": "string"
"server": {
"name": "string"
"share": {
"name": "string"
"file_system": "string",
"host_management_url": "string",
"host_name": "string",
"name": "string",
"nfs_access": [
"type": "string",
"uuid": "string"
"export_policy": {
"name": "string"
"ips": [
"string"
"path": "string",
"permissions": [
"access": "string",
"host": "string"
"nvme_access": [
"type": "string",
"uuid": "string"
"subsystem_map": {
"anagrpid": "string",
"nsid": "string",
"subsystem": {
"hosts": [
"nqn": "string"
"name": "string",
"uuid": "string"
"protection_groups": [
"name": "string",
"rpo": {
"local": {
"description": "string",
"name": "string"
"remote": {
"name": "string"
"uuid": "string"
"san_access": [
"type": "string",
"uuid": "string"
"lun_mappings": [
"fcp": [
"interface": {
"name": "lif1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"wwpn": "20:00:00:50:56:b4:13:a8"
"igroup": {
"initiators": [
"string"
"name": "string",
"uuid": "string"
"iscsi": [
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"port": 3260
"lun_id": 0
"serial_number": "string"
"storage_service": {
"name": "string",
"uuid": "string"
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
application
_links |
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
application_lun_object
LUN object
creation_timestamp |
string |
LUN creation time |
path |
string |
LUN path |
size |
integer |
LUN size |
uuid |
string |
LUN UUID |
application_namespace_object
Namespace object
_links |
string |
Namespace creation time |
name |
string |
Namespace name |
size |
integer |
Namespace size |
uuid |
string |
Namespace UUID |
application_volume_object
Volume object
string |
Creation time |
name |
string |
Name |
size |
integer |
Size |
uuid |
string |
UUID |
application_backing_storage
luns |
array[application_lun_object] |
namespaces |
array[application_namespace_object] |
volumes |
array[application_volume_object] |
backing_storage
type |
string |
Backing storage type |
uuid |
string |
Backing storage UUID |
permissions
access |
string |
Access granted to the user or group |
user_or_group |
string |
User or group |
server
name |
string |
Server name |
name |
string |
Share name |
application_cifs_properties
backing_storage |
ips |
array[string] |
path |
string |
Junction path |
permissions |
array[permissions] |
server |
share |
export_policy
name |
string |
Export policy name |
permissions
access |
string |
Access granted to the host |
host |
string |
Host granted access |
application_nfs_properties
backing_storage |
export_policy |
ips |
array[string] |
path |
string |
Junction path |
permissions |
self
self |
_links
self |
hosts
_links |
nqn |
string |
Host |
subsystem
_links |
hosts |
array[hosts] |
name |
string |
Subsystem name |
uuid |
string |
Subsystem UUID |
subsystem_map
Subsystem map object
anagrpid |
string |
Subsystem ANA group ID |
nsid |
string |
Subsystem namespace ID |
subsystem |
application_nvme_access
Application NVME access
backing_storage |
is_clone |
boolean |
Clone |
subsystem_map |
Subsystem map object |
local
description |
string |
A detailed description of the local RPO. This includes details on the Snapshot copy schedule. |
name |
string |
The local RPO of the component. This indicates how often component Snapshot copies are automatically created. |
remote
description |
string |
A detailed description of the remote RPO. |
name |
string |
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster. |
rpo
local |
remote |
application_protection_groups
name |
string |
Protection group name |
rpo |
uuid |
string |
Protection group UUID |
fc_interface_reference
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
application_san_access_fcp_endpoint
A Fibre Channel Protocol (FCP) access endpoint for the LUN.
interface |
An FC interface. |
igroup
initiators |
array[string] |
name |
string |
Igroup name |
uuid |
string |
Igroup UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
application_san_access_iscsi_endpoint
An iSCSI access endpoint for the LUN.
_links |
interface |
port |
integer |
The TCP port number of the iSCSI access endpoint. |
application_lun_mapping_object
fcp |
All possible Fibre Channel Protocol (FCP) access endpoints for the LUN. |
igroup |
iscsi |
All possible iSCSI access endpoints for the LUN. |
lun_id |
integer |
LUN ID |
backing_storage |
is_clone |
boolean |
Clone |
lun_mappings |
serial_number |
string |
LUN serial number |
storage_service
name |
string |
Storage service name |
uuid |
string |
Storage service UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
Application component
_links |
application |
backing_storage |
cifs_access |
array[application_cifs_properties] |
file_system |
string |
Defines the type of file system that will be installed on this application component. |
host_management_url |
string |
Host management URL |
host_name |
string |
L2 Host FQDN |
name |
string |
Application component name |
nfs_access |
array[application_nfs_properties] |
nvme_access |
array[application_nvme_access] |
protection_groups |
san_access |
array[application_san_access] |
storage_service |
svm |
uuid |
string |
The application component UUID. Valid in URL. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
