Retrieve applications
GET /application/applications
Retrieves applications.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
<template>the property corresponding to thetemplate.nameof the application
Query examples
Numerous queries are available for classifying and sorting applications:
Return a list of applications sorted by name.
GET /application/applications?order_by=name
Return a list of applications for a specific SVM.
GET /application/applications?svm.name=<name>
Return a list of all SQL applications.
GET /application/applications?template.name=sql*
Return a list of all applications that can be accessed via SAN.
GET /application/applications?template.protocol=san
Return the top five applications consuming the most IOPS.
GET /application/applications?order_by=statistics.iops.total desc&max_records=5
The above examples are not comprehensive. There are many more properties available for queries. Also, multiple queries can be mixed and matched with other query parameters for a large variety of requests. See the per-property documentation below for the full list of supported query parameters.
Learn more
uuid |
string |
query |
False |
Filter by UUID |
name |
string |
query |
False |
Filter by name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
template.name |
string |
query |
False |
Filter by template.name |
template.version |
string |
query |
False |
Filter by template.version |
template.protocol |
string |
query |
False |
Filter by template.protocol |
generation |
string |
query |
False |
Filter by generation |
state |
string |
query |
False |
Filter by state |
protection_granularity |
string |
query |
False |
Filter by protection granularity |
rpo.is_supported |
string |
query |
False |
Filter by rpo.is_supported |
rpo.local.name |
string |
query |
False |
Filter by rpo.local.name |
rpo.local.description |
string |
query |
False |
Filter by rpo.local.description |
rpo.remote.name |
string |
query |
False |
Filter by rpo.remote.name |
rpo.remote.description |
string |
query |
False |
Filter by rpo.remote.description |
rpo.components.name |
string |
query |
False |
Filter by rpo.components.name |
rpo.components.uuid |
string |
query |
False |
Filter by rpo.components.uuid |
rpo.components.rpo.local.name |
string |
query |
False |
Filter by rpo.components.rpo.local.name |
rpo.components.rpo.local.description |
string |
query |
False |
Filter by rpo.components.rpo.local.description |
rpo.components.rpo.remote.name |
string |
query |
False |
Filter by rpo.components.rpo.remote.name |
rpo.components.rpo.remote.description |
string |
query |
False |
Filter by rpo.components.rpo.remote.description |
statistics.space.provisioned |
string |
query |
False |
Filter by statistics.space.provisioned |
statistics.space.used |
string |
query |
False |
Filter by statistics.space.used |
statistics.space.used_percent |
string |
query |
False |
Filter by statistics.space.used_percent |
statistics.space.used_excluding_reserves |
string |
query |
False |
Filter by statistics.space.used_excluding_reserves |
statistics.space.logical_used |
string |
query |
False |
Filter by statistics.space.logical_used |
statistics.space.reserved_unused |
string |
query |
False |
Filter by statistics.space.reserved_unused |
statistics.space.available |
string |
query |
False |
Filter by statistics.space.available |
statistics.space.savings |
string |
query |
False |
Filter by statistics.space.savings |
statistics.iops.total |
string |
query |
False |
Filter by statistics.iops.total |
statistics.iops.per_tb |
string |
query |
False |
Filter by statistics.iops.per_tb |
statistics.snapshot.reserve |
string |
query |
False |
Filter by statistics.snapshot.reserve |
statistics.snapshot.used |
string |
query |
False |
Filter by statistics.snapshot.used |
statistics.latency.raw |
string |
query |
False |
Filter by statistics.latency.raw |
statistics.latency.average |
string |
query |
False |
Filter by statistics.latency.average |
statistics.statistics_incomplete |
string |
query |
False |
Filter by statistics.statistics_incomplete |
statistics.shared_storage_pool |
string |
query |
False |
Filter by statistics.shared_storage_pool |
statistics.components.name |
string |
query |
False |
Filter by statistics.components.name |
statistics.components.uuid |
string |
query |
False |
Filter by statistics.components.uuid |
statistics.components.storage_service.name |
string |
query |
False |
Filter by statistics.components.storage_service.name |
statistics.components.space.provisioned |
string |
query |
False |
Filter by statistics.components.space.provisioned |
statistics.components.space.used |
string |
query |
False |
Filter by statistics.components.space.used |
statistics.components.space.used_percent |
string |
query |
False |
Filter by statistics.components.space.used_percent |
statistics.components.space.used_excluding_reserves |
string |
query |
False |
Filter by statistics.components.space.used_excluding_reserves |
statistics.components.space.logical_used |
string |
query |
False |
Filter by statistics.components.space.logical_used |
statistics.components.space.reserved_unused |
string |
query |
False |
Filter by statistics.components.space.reserved_unused |
statistics.components.space.available |
string |
query |
False |
Filter by statistics.components.space.available |
statistics.components.space.savings |
string |
query |
False |
Filter by statistics.components.space.savings |
statistics.components.iops.total |
string |
query |
False |
Filter by statistics.components.iops.total |
statistics.components.iops.per_tb |
string |
query |
False |
Filter by statistics.components.iops.per_tb |
statistics.components.snapshot.reserve |
string |
query |
False |
Filter by statistics.components.snapshot.reserve |
statistics.components.snapshot.used |
string |
query |
False |
Filter by statistics.components.snapshot.used |
statistics.components.latency.raw |
string |
query |
False |
Filter by statistics.components.latency.raw |
statistics.components.latency.average |
string |
query |
False |
Filter by statistics.components.latency.average |
statistics.components.statistics_incomplete |
string |
query |
False |
Filter by statistics.components.statistics_incomplete |
statistics.components.shared_storage_pool |
string |
query |
False |
Filter by statistics.components.shared_storage_pool |
smart_container |
string |
query |
False |
Filter by smart_container |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[application] |
"next": {
"href": "/api/resourcelink"
"records": [
"snapshots": {
"creation_timestamp": "string",
"generation": 0,
"maxdata_on_san": {
"app_type": "string",
"application_components": [
"metadata": [
"key": "string",
"value": "string"
"ocsm_url": "string",
"os_type": "string"
"name": "string",
"nas": {
"cifs_access": [
"access": "string",
"user_or_group": "string"
"nfs_access": [
"access": "string",
"host": "string"
"protection_type": {
"local_policy": "string",
"local_rpo": "string",
"remote_rpo": "string"
"nvme": {
"components": [
"os_type": "string",
"rpo": {
"local": {
"name": "string",
"policy": "string"
"protection_granularity": "string",
"rpo": {
"components": [
"name": "string",
"rpo": {
"local": {
"description": "string",
"name": "string"
"remote": {
"name": "string"
"uuid": "string"
"local": {
"name": "string"
"remote": {
"name": "string"
"san": {
"state": "string",
"statistics": {
"components": [
"iops": {
"per_tb": 0,
"total": 0
"latency": {
"average": 0,
"raw": 0
"name": "string",
"snapshot": {
"reserve": 0,
"used": 0
"space": {
"available": 0,
"logical_used": 0,
"provisioned": 0,
"reserved_unused": 0,
"savings": 0,
"used": 0,
"used_excluding_reserves": 0,
"used_percent": 0
"storage_service": {
"name": "string",
"uuid": "string"
"uuid": "string"
"iops": {
"per_tb": 0,
"total": 0
"latency": {
"average": 0,
"raw": 0
"snapshot": {
"reserve": 0,
"used": 0
"space": {
"available": 0,
"logical_used": 0,
"provisioned": 0,
"savings": 0,
"used": 0,
"used_percent": 0
"svm": {
"name": "string",
"uuid": "string"
"template": {
"name": "string",
"protocol": "string",
"version": 0
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
snapshots |
metadata
key |
string |
Key to look up metadata associated with an application component. |
value |
string |
Value associated with the key. |
protection_type
local_rpo |
string |
The local rpo of the application component. |
remote_rpo |
string |
The remote rpo of the application component. |
storage_service
name |
string |
The storage service of the application component. |
maxdata_on_san_application_components
The list of application components to be created.
file_system |
string |
Defines the type of file system that will be installed on this application component. |
host_management_url |
string |
The host management URL for this application component. |
host_name |
string |
FQDN of the L2 host that contains the hot tier of this application component. |
igroup_name |
string |
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. |
lun_count |
integer |
The number of LUNs in the application component. |
metadata |
array[metadata] |
name |
string |
The name of the application component. |
protection_type |
storage_service |
total_size |
integer |
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} |
metadata
key |
string |
Key to look up metadata associated with an application. |
value |
string |
maxdata_on_san_new_igroups
The list of initiator groups to create.
initiators |
array[string] |
maxdata_on_san
MAX Data application using SAN.
app_type |
string |
Type of the application that is being deployed on the L2. |
application_components |
The list of application components to be created. |
metadata |
array[metadata] |
ocsm_url |
string |
The OnCommand System Manager URL for this application. |
os_type |
string |
The name of the host OS running the application. |
storage_service
name |
string |
The storage service of the database. |
dataset
element_count |
integer |
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range. |
replication_factor |
integer |
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary. |
size |
integer |
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
mongo_db_on_san_new_igroups
initiators |
array[string] |
protection_type
local_rpo |
string |
The local rpo of the application. |
remote_rpo |
string |
The remote rpo of the application. |
secondary_igroups
name |
string |
The name of the initiator group for each secondary. |
mongo_db_on_san
MongoDB using SAN.
dataset |
os_type |
string |
primary_igroup_name |
string |
The initiator group for the primary. |
protection_type |
secondary_igroups |
array[secondary_igroups] |
component
name |
string |
Name of the source component. |
svm
name |
string |
Name of the source SVM. |
origin
component |
svm |
flexcache
origin |
object_stores
nas_application_components_tiering
application-components.tiering
policy |
string |
The storage tiering type of the application component. |
flexcache |
name |
string |
scale_out |
boolean |
Denotes a Flexgroup. |
share_count |
integer |
The number of shares in the application component. |
storage_service |
tiering |
application-components.tiering |
total_size |
integer |
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]} |
app_cifs_access
The list of CIFS access controls.
access |
string |
The CIFS access granted to the user or group. |
user_or_group |
string |
The name of the CIFS user or group that will be granted access. |
app_nfs_access
The list of NFS access controls.
access |
string |
The NFS access granted. |
host |
string |
The name of the NFS entity granted access. |
protection_type
local_policy |
string |
The snapshot policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy> |
local_rpo |
string |
remote_rpo |
string |
nas
A generic NAS application.
array[application_components] |
cifs_access |
array[app_cifs_access] |
The list of CIFS access controls. |
nfs_access |
array[app_nfs_access] |
The list of NFS access controls. |
protection_type |
performance
storage_service |
hosts
nqn |
string |
The host NQN. |
zapp_nvme_components_subsystem
components.subsystem
hosts |
array[hosts] |
name |
string |
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not. |
os_type |
string |
The name of the host OS accessing the component. The default value is the host OS that is running the application. |
uuid |
string |
The UUID of an existing subsystem to be granted access to the component. Usage: <UUID> |
zapp_nvme_components_tiering
policy |
string |
components
name |
string |
namespace_count |
integer |
The number of namespaces in the component |
performance |
subsystem |
components.subsystem |
tiering |
total_size |
integer |
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]} |
local
name |
string |
policy |
string |
rpo
local |
zapp_nvme
An NVME application.
components |
array[components] |
os_type |
string |
rpo |
storage_service
name |
string |
The storage service of the archive log. |
archive_log
size |
integer |
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
db
size |
integer |
storage_service |
storage_service
name |
string |
The storage service of the ORACLE_HOME storage volume. |
ora_home
size |
integer |
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the redo log group. |
redo_log
mirrored |
boolean |
Specifies whether the redo log group should be mirrored. |
size |
integer |
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_on_nfs
Oracle using NFS.
archive_log |
db |
nfs_access |
ora_home |
protection_type |
redo_log |
oracle_on_san_new_igroups
initiators |
array[string] |
oracle_on_san
Oracle using SAN.
archive_log |
db |
igroup_name |
string |
ora_home |
os_type |
string |
protection_type |
redo_log |
storage_service
name |
string |
The storage service of the Oracle grid binary storage volume. |
grid_binary
size |
integer |
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the Oracle CRS volume. |
oracle_crs
copies |
integer |
The number of CRS volumes. |
size |
integer |
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_rac_on_nfs
Oracle RAC using NFS.
archive_log |
db |
grid_binary |
nfs_access |
ora_home |
oracle_crs |
protection_type |
redo_log |
db_sids
igroup_name |
string |
oracle_rac_on_san_new_igroups
initiators |
array[string] |
oracle_rac_on_san
Oracle RAC using SAN.
archive_log |
db |
db_sids |
array[db_sids] |
grid_binary |
ora_home |
oracle_crs |
os_type |
string |
protection_type |
redo_log |
local
description |
string |
A detailed description of the local RPO. This will include details about the Snapshot copy schedule. |
name |
string |
The local RPO of the component. This indicates how often component Snapshot copies are automatically created. |
remote
description |
string |
A detailed description of the remote RPO. |
name |
string |
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster. |
rpo
local |
remote |
components
name |
string |
Component Name. |
rpo |
uuid |
string |
Component UUID. |
local
description |
string |
name |
string |
The local RPO of the application. This indicates how often application Snapshot copies are automatically created. |
remote
description |
string |
name |
string |
The remote RPO of the application. A remote RPO of zero indicates that the application is synchronously replicated to another cluster. |
rpo
components |
array[components] |
is_supported |
boolean |
Is RPO supported for this application? Generation 1 applications did not support Snapshot copies or MetroCluster. |
local |
remote |
san_application_components_tiering
policy |
string |
igroup_name |
string |
lun_count |
integer |
name |
string |
storage_service |
tiering |
total_size |
integer |
san_new_igroups
initiators |
array[string] |
san
A generic SAN application.
os_type |
string |
protection_type |
storage_service
name |
string |
The storage service of the DB. |
db
size |
integer |
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the log DB. |
log
size |
integer |
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san_new_igroups
initiators |
array[string] |
storage_service
name |
string |
The storage service of the temp DB. |
temp_db
size |
integer |
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san
Microsoft SQL using SAN.
db |
igroup_name |
string |
log |
os_type |
string |
protection_type |
server_cores_count |
integer |
The number of server cores for the DB. |
temp_db |
access
installer |
string |
SQL installer admin user name. |
service_account |
string |
SQL service account user name. |
sql_on_smb
Microsoft SQL using SMB.
access |
db |
log |
protection_type |
integer |
temp_db |
iops
per_tb |
integer |
The number of IOPS per terabyte of logical space currently being used by the application component. |
total |
integer |
The total number of IOPS being used by the application component. |
latency
average |
integer |
The cumulative average response time in microseconds for this component. |
raw |
integer |
The cumulative response time in microseconds for this component. |
snapshot
reserve |
integer |
The amount of space reserved by the system for Snapshot copies. |
used |
integer |
The amount of spacing currently in use by the system to store Snapshot copies. |
space
available |
integer |
The available amount of space left in the application component. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
logical_used |
integer |
The amount of space that would currently be used if no space saving features were enabled. For example, if compression were the only space saving feature enabled, this field would represent the uncompressed amount of space used. |
provisioned |
integer |
The originally requested amount of space that was provisioned for the application component. |
reserved_unused |
integer |
The amount of space reserved for system features such as Snapshot copies that has not yet been used. |
savings |
integer |
The amount of space saved by all enabled space saving features. |
used |
integer |
The amount of space that is currently being used by the application component. Note that this includes any space reserved by the system for features such as Snapshot copies. |
integer |
The amount of space that is currently being used, excluding any space that is reserved by the system for features such as Snapshot copies. |
used_percent |
integer |
The percentage of the originally provisioned space that is currently being used by the application component. |
storage_service
name |
string |
The storage service name. AFF systems support the extreme storage service. All other systems only support value. |
uuid |
string |
The storage service UUID. |
components
iops |
latency |
name |
string |
Component Name. |
boolean |
An application component is considered to use a shared storage pool if storage elements for for other components reside on the same aggregate as storage elements for this component. |
snapshot |
space |
boolean |
If not all storage elements of the application component are currently available, the returned statistics might only include data from those elements that were available. |
storage_service |
uuid |
string |
Component UUID. |
iops
per_tb |
integer |
The number of IOPS per terabyte of logical space currently being used by the application. |
total |
integer |
The total number of IOPS being used by the application. |
latency
average |
integer |
The cumulative average response time in microseconds for this application. |
raw |
integer |
The cumulative response time in microseconds for this application. |
space
available |
integer |
The available amount of space left in the application. Note that this field has limited meaning for SAN applications. Space may be considered used from ONTAP's perspective while the host filesystem still considers it available.
logical_used |
integer |
provisioned |
integer |
The originally requested amount of space that was provisioned for the application. |
reserved_unused |
integer |
savings |
integer |
used |
integer |
The amount of space that is currently being used by the application. Note that this includes any space reserved by the system for features such as Snapshot copies. |
integer |
used_percent |
integer |
The percentage of the originally provisioned space that is currently being used by the application. |
statistics
components |
array[components] |
iops |
latency |
boolean |
An application is considered to use a shared storage pool if storage elements for multiple components reside on the same aggregate. |
snapshot |
space |
boolean |
If not all storage elements of the application are currently available, the returned statistics might only include data from those elements that were available. |
svm
name |
string |
SVM Name. Either the SVM name or UUID must be provided to create an application. |
uuid |
string |
SVM UUID. Either the SVM name or UUID must be provided to create an application. |
self_link
self |
template
_links |
name |
string |
The name of the template that was used to provision this application. |
protocol |
string |
The protocol access of the template that was used to provision this application. |
version |
integer |
The version of the template that was used to provision this application. The template version changes only if the layout of the application changes over time. For example, redo logs in Oracle RAC templates were updated and provisioned differently in DATA ONTAP 9.3.0 compared to prior releases, so the version number was increased. If layouts change in the future, the changes will be documented along with the corresponding version numbers.
storage_service
name |
string |
The storage service of the desktops. |
desktops
count |
integer |
The number of desktops to support. |
size |
integer |
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
hyper_v_access
service_account |
string |
Hyper-V service account. |
vdi_on_nas
A VDI application using NAS.
desktops |
hyper_v_access |
nfs_access |
protection_type |
vdi_on_san_new_igroups
initiators |
array[string] |
vdi_on_san
A VDI application using SAN.
desktops |
hypervisor |
string |
The name of the hypervisor hosting the application. |
igroup_name |
string |
protection_type |
storage_service
name |
string |
The storage service of the datastore. |
datastore
count |
integer |
The number of datastores to support. |
size |
integer |
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
vsi_on_nas
A VSI application using NAS.
datastore |
hyper_v_access |
nfs_access |
protection_type |
vsi_on_san_new_igroups
initiators |
array[string] |
vsi_on_san
A VSI application using SAN.
datastore |
hypervisor |
string |
igroup_name |
string |
protection_type |
application
Applications
_links |
creation_timestamp |
string |
The time when the application was created. |
generation |
integer |
The generation number of the application. This indicates which features are supported on the application. For example, generation 1 applications do not support Snapshot copies. Support for Snapshot copies was added at generation 2. Any future generation numbers and their feature set will be documented. |
maxdata_on_san |
MAX Data application using SAN. |
mongo_db_on_san |
MongoDB using SAN. |
name |
string |
Application Name. This field is user supplied when the application is created. |
nas |
A generic NAS application. |
nvme |
An NVME application. |
oracle_on_nfs |
Oracle using NFS. |
oracle_on_san |
Oracle using SAN. |
oracle_rac_on_nfs |
Oracle RAC using NFS. |
oracle_rac_on_san |
Oracle RAC using SAN. |
string |
Protection granularity determines the scope of Snapshot copy operations for the application. Possible values are "application" and "component". If the value is "application", Snapshot copy operations are performed on the entire application. If the value is "component", Snapshot copy operations are performed separately on the application components. |
rpo |
san |
A generic SAN application. |
smart_container |
boolean |
Identifies if this is a smart container or not. |
sql_on_san |
Microsoft SQL using SAN. |
sql_on_smb |
Microsoft SQL using SMB. |
state |
string |
The state of the application. For full functionality, applications must be in the online state. Other states indicate that the application is in a transient state and not all operations are supported. |
statistics |
svm |
template |
uuid |
string |
Application UUID. This field is generated when the application is created. |
vdi_on_nas |
A VDI application using NAS. |
vdi_on_san |
A VDI application using SAN. |
vsi_on_nas |
A VSI application using NAS. |
vsi_on_san |
A VSI application using SAN. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
