Retrieve application templates
GET /application/templates
Retrieves application templates.
Query examples
The most useful queries on this API allows searches by name or protocol access. The following query returns all templates that are used to provision an Oracle application.
GET /application/templates?name=ora*
Similarly, the following query returns all templates that support SAN access.
GET /application/templates?protocol=san
Learn more
name |
string |
query |
False |
Filter by name |
protocol |
string |
query |
False |
Filter by protocol |
description |
string |
query |
False |
Filter by description |
missing_prerequisites |
string |
query |
False |
Filter by missing_prerequisites |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[application_template] |
"next": {
"href": "/api/resourcelink"
"records": [
"description": "string",
"maxdata_on_san": {
"app_type": "string",
"application_components": [
"metadata": [
"key": "string",
"value": "string"
"ocsm_url": "string",
"os_type": "string"
"missing_prerequisites": "string",
"name": "string",
"nas": {
"cifs_access": [
"access": "string",
"user_or_group": "string"
"nfs_access": [
"access": "string",
"host": "string"
"protection_type": {
"local_policy": "string",
"local_rpo": "string",
"remote_rpo": "string"
"nvme": {
"components": [
"os_type": "string",
"rpo": {
"local": {
"name": "string",
"policy": "string"
"protocol": "string",
"san": {
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
self_link
self |
metadata
key |
string |
Key to look up metadata associated with an application component. |
value |
string |
Value associated with the key. |
protection_type
local_rpo |
string |
The local rpo of the application component. |
remote_rpo |
string |
The remote rpo of the application component. |
storage_service
name |
string |
The storage service of the application component. |
maxdata_on_san_application_components
The list of application components to be created.
file_system |
string |
Defines the type of file system that will be installed on this application component. |
host_management_url |
string |
The host management URL for this application component. |
host_name |
string |
FQDN of the L2 host that contains the hot tier of this application component. |
igroup_name |
string |
The name of the initiator group through which the contents of this application will be accessed. Modification of this parameter is a disruptive operation. All LUNs in the application component will be unmapped from the current igroup and re-mapped to the new igroup. |
lun_count |
integer |
The number of LUNs in the application component. |
metadata |
array[metadata] |
name |
string |
The name of the application component. |
protection_type |
storage_service |
total_size |
integer |
The total size of the application component, split across the member LUNs. Usage: {<integer>[KB|MB|GB|TB|PB]} |
metadata
key |
string |
Key to look up metadata associated with an application. |
value |
string |
maxdata_on_san_new_igroups
The list of initiator groups to create.
initiators |
array[string] |
maxdata_on_san
MAX Data application using SAN.
app_type |
string |
Type of the application that is being deployed on the L2. |
application_components |
The list of application components to be created. |
metadata |
array[metadata] |
ocsm_url |
string |
The OnCommand System Manager URL for this application. |
os_type |
string |
The name of the host OS running the application. |
storage_service
name |
string |
The storage service of the database. |
dataset
element_count |
integer |
The number of storage elements (LUNs for SAN) of the database to maintain. Must be an even number between 2 and 16. Odd numbers will be rounded up to the next even number within range. |
replication_factor |
integer |
The number of data bearing members of the replicaset, including 1 primary and at least 1 secondary. |
size |
integer |
The size of the database. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
mongo_db_on_san_new_igroups
initiators |
array[string] |
protection_type
local_rpo |
string |
The local rpo of the application. |
remote_rpo |
string |
The remote rpo of the application. |
secondary_igroups
name |
string |
The name of the initiator group for each secondary. |
mongo_db_on_san
MongoDB using SAN.
dataset |
os_type |
string |
primary_igroup_name |
string |
The initiator group for the primary. |
protection_type |
secondary_igroups |
array[secondary_igroups] |
component
name |
string |
Name of the source component. |
svm
name |
string |
Name of the source SVM. |
origin
component |
svm |
flexcache
origin |
object_stores
nas_application_components_tiering
application-components.tiering
policy |
string |
The storage tiering type of the application component. |
flexcache |
name |
string |
scale_out |
boolean |
Denotes a Flexgroup. |
share_count |
integer |
The number of shares in the application component. |
storage_service |
tiering |
application-components.tiering |
total_size |
integer |
The total size of the application component, split across the member shares. Usage: {<integer>[KB|MB|GB|TB|PB]} |
app_cifs_access
The list of CIFS access controls.
access |
string |
The CIFS access granted to the user or group. |
user_or_group |
string |
The name of the CIFS user or group that will be granted access. |
app_nfs_access
The list of NFS access controls.
access |
string |
The NFS access granted. |
host |
string |
The name of the NFS entity granted access. |
protection_type
local_policy |
string |
The snapshot policy to apply to each volume in the smart container. This property is only supported for smart containers. Usage: <snapshot policy> |
local_rpo |
string |
remote_rpo |
string |
nas
A generic NAS application.
array[application_components] |
cifs_access |
array[app_cifs_access] |
The list of CIFS access controls. |
nfs_access |
array[app_nfs_access] |
The list of NFS access controls. |
protection_type |
performance
storage_service |
hosts
nqn |
string |
The host NQN. |
zapp_nvme_components_subsystem
components.subsystem
hosts |
array[hosts] |
name |
string |
The name of the subsystem accessing the component. If neither the name nor the UUID is provided, the name defaults to <application-name>_<component-name>, whether that subsystem already exists or not. |
os_type |
string |
The name of the host OS accessing the component. The default value is the host OS that is running the application. |
uuid |
string |
The UUID of an existing subsystem to be granted access to the component. Usage: <UUID> |
zapp_nvme_components_tiering
policy |
string |
components
name |
string |
namespace_count |
integer |
The number of namespaces in the component |
performance |
subsystem |
components.subsystem |
tiering |
total_size |
integer |
The total size of the component, spread across member namespaces. Usage: {<integer>[KB|MB|GB|TB|PB]} |
local
name |
string |
policy |
string |
rpo
local |
zapp_nvme
An NVME application.
components |
array[components] |
os_type |
string |
rpo |
storage_service
name |
string |
The storage service of the archive log. |
archive_log
size |
integer |
The size of the archive log. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
db
size |
integer |
storage_service |
storage_service
name |
string |
The storage service of the ORACLE_HOME storage volume. |
ora_home
size |
integer |
The size of the ORACLE_HOME storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the redo log group. |
redo_log
mirrored |
boolean |
Specifies whether the redo log group should be mirrored. |
size |
integer |
The size of the redo log group. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_on_nfs
Oracle using NFS.
archive_log |
db |
nfs_access |
ora_home |
protection_type |
redo_log |
oracle_on_san_new_igroups
initiators |
array[string] |
oracle_on_san
Oracle using SAN.
archive_log |
db |
igroup_name |
string |
ora_home |
os_type |
string |
protection_type |
redo_log |
storage_service
name |
string |
The storage service of the Oracle grid binary storage volume. |
grid_binary
size |
integer |
The size of the Oracle grid binary storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the Oracle CRS volume. |
oracle_crs
copies |
integer |
The number of CRS volumes. |
size |
integer |
The size of the Oracle CRS/voting storage volume. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
oracle_rac_on_nfs
Oracle RAC using NFS.
archive_log |
db |
grid_binary |
nfs_access |
ora_home |
oracle_crs |
protection_type |
redo_log |
db_sids
igroup_name |
string |
oracle_rac_on_san_new_igroups
initiators |
array[string] |
oracle_rac_on_san
Oracle RAC using SAN.
archive_log |
db |
db_sids |
array[db_sids] |
grid_binary |
ora_home |
oracle_crs |
os_type |
string |
protection_type |
redo_log |
san_application_components_tiering
policy |
string |
igroup_name |
string |
lun_count |
integer |
name |
string |
storage_service |
tiering |
total_size |
integer |
san_new_igroups
initiators |
array[string] |
san
A generic SAN application.
os_type |
string |
protection_type |
storage_service
name |
string |
The storage service of the DB. |
db
size |
integer |
The size of the DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
storage_service
name |
string |
The storage service of the log DB. |
log
size |
integer |
The size of the log DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san_new_igroups
initiators |
array[string] |
storage_service
name |
string |
The storage service of the temp DB. |
temp_db
size |
integer |
The size of the temp DB. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
sql_on_san
Microsoft SQL using SAN.
db |
igroup_name |
string |
log |
os_type |
string |
protection_type |
server_cores_count |
integer |
The number of server cores for the DB. |
temp_db |
access
installer |
string |
SQL installer admin user name. |
service_account |
string |
SQL service account user name. |
sql_on_smb
Microsoft SQL using SMB.
access |
db |
log |
protection_type |
integer |
temp_db |
storage_service
name |
string |
The storage service of the desktops. |
desktops
count |
integer |
The number of desktops to support. |
size |
integer |
The size of the desktops. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
hyper_v_access
service_account |
string |
Hyper-V service account. |
vdi_on_nas
A VDI application using NAS.
desktops |
hyper_v_access |
nfs_access |
protection_type |
vdi_on_san_new_igroups
initiators |
array[string] |
vdi_on_san
A VDI application using SAN.
desktops |
hypervisor |
string |
The name of the hypervisor hosting the application. |
igroup_name |
string |
protection_type |
storage_service
name |
string |
The storage service of the datastore. |
datastore
count |
integer |
The number of datastores to support. |
size |
integer |
The size of the datastore. Usage: {<integer>[KB|MB|GB|TB|PB]} |
storage_service |
vsi_on_nas
A VSI application using NAS.
datastore |
hyper_v_access |
nfs_access |
protection_type |
vsi_on_san_new_igroups
initiators |
array[string] |
vsi_on_san
A VSI application using SAN.
datastore |
hypervisor |
string |
igroup_name |
string |
protection_type |
Application templates
_links |
description |
string |
Description. |
maxdata_on_san |
MAX Data application using SAN. |
string |
Missing prerequisites. |
mongo_db_on_san |
MongoDB using SAN. |
name |
string |
Template name. |
nas |
A generic NAS application. |
nvme |
An NVME application. |
oracle_on_nfs |
Oracle using NFS. |
oracle_on_san |
Oracle using SAN. |
oracle_rac_on_nfs |
Oracle RAC using NFS. |
oracle_rac_on_san |
Oracle RAC using SAN. |
protocol |
string |
Access protocol. |
san |
A generic SAN application. |
sql_on_san |
Microsoft SQL using SAN. |
sql_on_smb |
Microsoft SQL using SMB. |
vdi_on_nas |
A VDI application using NAS. |
vdi_on_san |
A VDI application using SAN. |
vsi_on_nas |
A VSI application using NAS. |
vsi_on_san |
A VSI application using SAN. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
