Retrieve nodes in a cluster
GET /cluster/nodes
Retrieves the nodes in the cluster.
Related ONTAP commands
system node show
Learn more
model |
string |
query |
False |
Filter by model |
service_processor.link_status |
string |
query |
False |
Filter by service_processor.link_status |
service_processor.dhcp_enabled |
boolean |
query |
False |
Filter by service_processor.dhcp_enabled |
service_processor.firmware_version |
string |
query |
False |
Filter by service_processor.firmware_version |
service_processor.ipv6_interface.address |
string |
query |
False |
Filter by service_processor.ipv6_interface.address |
service_processor.ipv6_interface.netmask |
integer |
query |
False |
Filter by service_processor.ipv6_interface.netmask |
service_processor.ipv6_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv6_interface.gateway |
service_processor.ipv4_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv4_interface.gateway |
service_processor.ipv4_interface.address |
string |
query |
False |
Filter by service_processor.ipv4_interface.address |
service_processor.ipv4_interface.netmask |
string |
query |
False |
Filter by service_processor.ipv4_interface.netmask |
service_processor.state |
string |
query |
False |
Filter by service_processor.state |
service_processor.mac_address |
string |
query |
False |
Filter by service_processor.mac_address |
uuid |
string |
query |
False |
Filter by uuid |
cluster_interfaces.name |
string |
query |
False |
Filter by cluster_interfaces.name |
cluster_interfaces.ip.address |
string |
query |
False |
Filter by cluster_interfaces.ip.address |
cluster_interfaces.uuid |
string |
query |
False |
Filter by cluster_interfaces.uuid |
date |
string |
query |
False |
Filter by date |
name |
string |
query |
False |
Filter by name |
membership |
string |
query |
False |
Filter by membership |
state |
string |
query |
False |
Filter by state |
serial_number |
string |
query |
False |
Filter by serial_number |
system_machine_type |
string |
query |
False |
Filter by system_machine_type |
vm.provider_type |
string |
query |
False |
Filter by vm.provider_type |
location |
string |
query |
False |
Filter by location |
ha.giveback.failure.message |
string |
query |
False |
Filter by ha.giveback.failure.message |
ha.giveback.failure.code |
integer |
query |
False |
Filter by ha.giveback.failure.code |
ha.giveback.state |
string |
query |
False |
Filter by ha.giveback.state |
ha.takeover.failure.code |
integer |
query |
False |
Filter by ha.takeover.failure.code |
ha.takeover.failure.message |
string |
query |
False |
Filter by ha.takeover.failure.message |
ha.takeover.state |
string |
query |
False |
Filter by ha.takeover.state |
ha.auto_giveback |
boolean |
query |
False |
Filter by ha.auto_giveback |
ha.partners.uuid |
string |
query |
False |
Filter by ha.partners.uuid |
ha.partners.name |
string |
query |
False |
Filter by ha.partners.name |
ha.ports.number |
unsigned |
query |
False |
Filter by ha.ports.number |
ha.ports.state |
string |
query |
False |
Filter by ha.ports.state |
ha.enabled |
boolean |
query |
False |
Filter by ha.enabled |
version.generation |
integer |
query |
False |
Filter by version.generation |
version.major |
integer |
query |
False |
Filter by version.major |
version.minor |
integer |
query |
False |
Filter by version.minor |
version.full |
string |
query |
False |
Filter by version.full |
system_id |
string |
query |
False |
Filter by system_id |
controller.frus.type |
string |
query |
False |
Filter by controller.frus.type |
controller.frus.id |
integer |
query |
False |
Filter by controller.frus.id |
controller.frus.state |
string |
query |
False |
Filter by controller.frus.state |
controller.flash_cache.firmware_version |
string |
query |
False |
Filter by controller.flash_cache.firmware_version |
controller.flash_cache.slot |
string |
query |
False |
Filter by controller.flash_cache.slot |
controller.flash_cache.part_number |
string |
query |
False |
Filter by controller.flash_cache.part_number |
controller.flash_cache.state |
string |
query |
False |
Filter by controller.flash_cache.state |
controller.flash_cache.hardware_revision |
string |
query |
False |
Filter by controller.flash_cache.hardware_revision |
controller.flash_cache.serial_number |
string |
query |
False |
Filter by controller.flash_cache.serial_number |
controller.flash_cache.model |
string |
query |
False |
Filter by controller.flash_cache.model |
controller.flash_cache.capacity |
integer |
query |
False |
Filter by controller.flash_cache.capacity |
controller.over_temperature |
string |
query |
False |
Filter by controller.over_temperature |
uptime |
integer |
query |
False |
Filter by uptime |
management_interfaces.name |
string |
query |
False |
Filter by management_interfaces.name |
management_interfaces.ip.address |
string |
query |
False |
Filter by management_interfaces.ip.address |
management_interfaces.uuid |
string |
query |
False |
Filter by management_interfaces.uuid |
vendor_serial_number |
string |
query |
False |
Filter by vendor_serial_number |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"cluster_interfaces": [
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"controller": {
"flash_cache": [
"capacity": 1024000000000,
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": 0,
"state": "string",
"type": "string"
"over_temperature": "string"
"date": "2019-04-17 11:49:26 -0400",
"ha": {
"giveback": {
"failure": {
"code": 852126,
"message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
"state": "failed"
"partners": [
"name": "node1",
"ports": [
"number": 0,
"state": "active"
"takeover": {
"failure": {
"code": 852130,
"message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
"state": "failed"
"location": "rack 2 row 5",
"management_interfaces": [
"ip": {
"name": "lif1",
"membership": "string",
"model": "FAS3070",
"name": "node-01",
"serial_number": "4048820-60-9",
"service_processor": {
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"ipv6_interface": {
"address": "fd20:8b1e:b255:5011:10:141:4:97",
"gateway": "fd20:8b1e:b255:5011:10::1",
"netmask": 64
"link_status": "string",
"mac_address": "string",
"state": "string"
"state": "string",
"system_id": 92027651,
"system_machine_type": "7Y56-CTOWW1",
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"vendor_serial_number": 791603000068,
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
"vm": {
"provider_type": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
address |
string |
cluster_interfaces
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
flash_cache
capacity |
integer |
Size in bytes |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
integer |
state |
string |
type |
string |
controller
Controller information
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
List of FRUs on the node. Only returned when requested by name. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
failure
Indicates the failure code and message.
code |
integer |
Message code |
message |
string |
Detailed message based on the state. |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure |
Indicates the failure code and message. |
state |
string |
partners
_links |
name |
string |
uuid |
string |
ports
number |
unsigned |
HA port number |
state |
string |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure |
state |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
giveback |
Represents the state of the node that is giving storage back to its HA partner. |
partners |
array[partners] |
Nodes in this node's High Availability (HA) group. |
ports |
array[ports] |
takeover |
This represents the state of the node that is taking over storage from its HA partner. |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
_links |
ip |
IP information |
name |
string |
uuid |
string |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipv6_interface
address |
string |
IPv6 address |
gateway |
string |
The IPv6 address of the default router. |
netmask |
integer |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127. |
service_processor
dhcp_enabled |
boolean |
Set to "true" to use DHCP to configure an IPv4 interface. |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to setup an interface along with its default router. |
ipv6_interface |
link_status |
string |
mac_address |
string |
state |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
vm
provider_type |
string |
Cloud provider where the VM is hosted. |
records
Complete node information
_links |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
ha |
location |
string |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
model |
string |
name |
string |
serial_number |
string |
service_processor |
state |
string |
State of the node:
system_id |
string |
string |
OEM system machine type. |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
string |
OEM vendor serial number. |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
vm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
