Retrieve the cluster configuration
GET /cluster
Retrieves the cluster configuration.
Learn more
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
desc] direction. Default direction is 'asc' for ascending.  |
fields  |
array[string]  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
certificate  |
Certificate used by cluster and node management interfaces for TLS connection requests.  |
contact  |
string  |
dns_domains  |
array[string]  |
A list of DNS domains. Domain names have the following requirements:
location  |
string  |
management_interfaces  |
array[management_interfaces]  |
metric  |
Performance numbers, such as IOPS latency and throughput.  |
name  |
string  |
name_servers  |
array[string]  |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.  |
ntp_servers  |
array[string]  |
Host name, IPv4 address, or IPv6 address for the external NTP time servers.  |
san_optimized  |
boolean  |
Specifies if this cluster is an All SAN Array.  |
statistics  |
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.  |
timezone  |
Provides the cluster-wide time zone information that localizes time found on messages displayed on each node's:
uuid  |
string  |
version  |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.  |
      "href": "/api/resourcelink"
  "certificate": {
  "contact": "support@company.com",
  "dns_domains": [
    "example.com",
    "example2.example3.com"
  "location": "building 1",
  "management_interfaces": [
      "ip": {
        "address": "10.10.10.7"
      "name": "lif1",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25 11:20:13 UTC"
  "name": "cluster1",
  "name_servers": [
    "10.224.65.20",
    "2001:db08:a0b:12f0::1"
  "ntp_servers": [
    "time.nist.gov",
    "10.98.19.20",
    "2610:20:6F15:15::27"
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "timezone": {
    "name": "America/New_York"
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "version": {
    "full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
    "generation": 9,
    "major": 4,
    "minor": 0
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
certificate
_links  |
uuid  |
string  |
Certificate UUID  |
configuration_backup
password  |
string  |
url  |
string  |
An external backup location for the cluster configuration. This is mostly required for single node clusters where node and cluster configuration backups cannot be copied to other nodes in the cluster.  |
username  |
string  |
validate_certificate  |
boolean  |
Use this parameter with the value "true" to validate the digital certificate of the remote server. Digital certificate validation is available only when the HTTPS protocol is used in the URL; it is disabled by default.  |
license
License keys or NLF contents.
keys  |
array[string]  |
ip
Object to setup an interface along with its default router.
address  |
string  |
IPv4 or IPv6 address  |
gateway  |
string  |
The IPv4 or IPv6 address of the default router.  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.  |
The management interface of the cluster. The subnet mask and gateway for this interface are used for the node management interfaces provided in the node configuration.
ip  |
Object to setup an interface along with its default router.  |
ip
IP information
address  |
string  |
_links  |
ip  |
IP information  |
name  |
string  |
The name of the interface.  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
iops
other  |
integer  |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.  |
read  |
integer  |
Performance metric for read I/O operations.  |
total  |
integer  |
Performance metric aggregated over all types of I/O operations.  |
write  |
integer  |
Peformance metric for write I/O operations.  |
latency
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
throughput
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
metric
_links  |
duration  |
string  |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:  |
iops  |
The rate of I/O operations observed at the storage object.  |
latency  |
The round trip latency in microseconds observed at the storage object.  |
status  |
string  |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.  |
throughput  |
The rate of throughput bytes per second observed at the storage object.  |
timestamp  |
string  |
The timestamp of the performance data.  |
node_setup_ip
The IP configuration for cluster setup.
address  |
string  |
cluster_interface
The cluster network IP address of the node to be added.
cluster_interfaces
Network interface
_links  |
ip  |
IP information  |
name  |
string  |
uuid  |
string  |
flash_cache
capacity  |
integer  |
Size in bytes  |
firmware_version  |
string  |
hardware_revision  |
string  |
model  |
string  |
part_number  |
string  |
serial_number  |
string  |
slot  |
string  |
state  |
string  |
frus
id  |
integer  |
state  |
string  |
type  |
string  |
controller
Controller information
flash_cache  |
array[flash_cache]  |
A list of Flash-Cache devices. Only returned when requested by name.  |
frus  |
array[frus]  |
List of FRUs on the node. Only returned when requested by name.  |
over_temperature  |
string  |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds.  |
failure
Indicates the failure code and message.
code  |
integer  |
Message code  |
message  |
string  |
Detailed message based on the state.  |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure  |
Indicates the failure code and message.  |
state  |
string  |
partners
_links  |
name  |
string  |
uuid  |
string  |
ports
number  |
unsigned  |
HA port number  |
state  |
string  |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure  |
state  |
string  |
ha
auto_giveback  |
boolean  |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready.  |
enabled  |
boolean  |
Specifies whether or not storage failover is enabled.  |
giveback  |
Represents the state of the node that is giving storage back to its HA partner.  |
partners  |
array[partners]  |
Nodes in this node's High Availability (HA) group.  |
ports  |
array[ports]  |
takeover  |
This represents the state of the node that is taking over storage from its HA partner.  |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
_links  |
ip  |
IP information  |
name  |
string  |
uuid  |
string  |
ipv4_interface
address  |
string  |
gateway  |
string  |
netmask  |
string  |
ipv6_interface
address  |
string  |
IPv6 address  |
gateway  |
string  |
The IPv6 address of the default router.  |
netmask  |
integer  |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127.  |
service_processor
dhcp_enabled  |
boolean  |
Set to "true" to use DHCP to configure an IPv4 interface.  |
firmware_version  |
string  |
The version of firmware installed.  |
ipv4_interface  |
ipv6_interface  |
link_status  |
string  |
mac_address  |
string  |
state  |
string  |
version
full  |
string  |
The full cluster version string.  |
generation  |
integer  |
The generation portion of the version.  |
major  |
integer  |
The major portion of the version.  |
minor  |
integer  |
The minor portion of the version.  |
vm
provider_type  |
string  |
Cloud provider where the VM is hosted.  |
nodes
Complete node information
_links  |
cluster_interfaces  |
array[cluster_interfaces]  |
controller  |
Controller information  |
date  |
string  |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
ha  |
location  |
string  |
membership  |
string  |
Possible values:
model  |
string  |
name  |
string  |
serial_number  |
string  |
service_processor  |
state  |
string  |
State of the node:
system_id  |
string  |
system_machine_type  |
string  |
OEM system machine type.  |
uptime  |
integer  |
The total time, in seconds, that the node has been up.  |
uuid  |
string  |
vendor_serial_number  |
string  |
OEM vendor serial number.  |
version  |
vm  |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other  |
integer  |
read  |
integer  |
total  |
integer  |
write  |
integer  |
statistics
iops_raw  |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.  |
latency_raw  |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.  |
status  |
string  |
throughput_raw  |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.  |
timestamp  |
string  |
timezone
console messages;
logging to internal ONTAP log files; and
localized REST API full ISO-8601 date, time, and time zone format information. Machine-to-machine interfaces, such as file access protocols (NFS, CIFS), block access protocols (SAN), and other protocols such as Manage ONTAP (ONTAPI), use second or subsecond time values that are based on world time or UTC.
name  |
string  |
The ONTAP time zone name or identification in either IANA time zone format "Area/Location", or an ONTAP traditional time zone. The initial first node in cluster setting for time zone is "Etc/UTC". "Etc/UTC" is the IANA timezone "Area/Location" specifier for Coordinated Universal Time (UTC), which is an offset of 0. IANA time zone formatThe IANA time zone, formatted as "Area/Location", is based on geographic areas that have had the same time zone offset for many years. "Location" represents a compound name using additional forward slashes. An example of the "Area/Location" time zone is "America/New_York" and represents most of the United States Eastern Time Zone. Examples of "Area/Location" with "Location" as a compound name are "America/Argentina/Buenos_Aires" and "America/Indiana/Indianapolis". ONTAP traditional time zoneExamples of the traditional time zones are "EST5EDT" for the United States Eastern Time Zone and "CET" for Central European Time Zone.
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
