REST API reference
Retrieves details of a broadcast domain
GET /network/ethernet/broadcast-domains/{uuid}
Retrieves details of a broadcast domain.
  • network port broadcast-domain show
uuid
string
path
True
Broadcast domain UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
      "href": "/api/resourcelink"
  "ipspace": {
    "name": "exchange",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
_links
_links
name
string
node
node
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
