Retrieve an FC WWPN alias
GET /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Retrieves an FC WWPN alias.
Related ONTAP commands
vserver fcp wwpn-alias show
Learn more
svm.uuid  |
string  |
path  |
True  |
The unique identifier of the SVM in which the alias is found.  |
alias  |
string  |
path  |
True  |
The name of FC WWPN alias.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
alias  |
string  |
The FC WWPN alias. Required in POST.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
wwpn  |
string  |
The FC initiator WWPN. Required in POST.  |
      "href": "/api/resourcelink"
  "alias": "host1",
  "svm": {
    "name": "svm1",
  "wwpn": "2f:a0:00:a0:98:0b:56:13"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1260882  |
The supplied SVM does not exist.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
