Retrieve all IP interface details
GET /network/ip/interfaces
Retrieves the details of all IP interfaces.
Related ONTAP Commands
network interface show
Learn more
ip.netmask  |
string  |
query  |
False  |
Filter by ip.netmask  |
ip.address  |
string  |
query  |
False  |
Filter by ip.address  |
ip.family  |
string  |
query  |
False  |
Filter by ip.family  |
scope  |
string  |
query  |
False  |
Filter by scope  |
vip  |
boolean  |
query  |
False  |
Filter by vip  |
service_policy.name  |
string  |
query  |
False  |
Filter by service_policy.name  |
service_policy.uuid  |
string  |
query  |
False  |
Filter by service_policy.uuid  |
state  |
string  |
query  |
False  |
Filter by state  |
name  |
string  |
query  |
False  |
Filter by name  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
enabled  |
boolean  |
query  |
False  |
Filter by enabled  |
location.failover  |
string  |
query  |
False  |
Filter by location.failover  |
location.port.name  |
string  |
query  |
False  |
Filter by location.port.name  |
location.port.node.name  |
string  |
query  |
False  |
Filter by location.port.node.name  |
location.port.uuid  |
string  |
query  |
False  |
Filter by location.port.uuid  |
location.home_node.uuid  |
string  |
query  |
False  |
Filter by location.home_node.uuid  |
location.home_node.name  |
string  |
query  |
False  |
Filter by location.home_node.name  |
location.home_port.name  |
string  |
query  |
False  |
Filter by location.home_port.name  |
location.home_port.node.name  |
string  |
query  |
False  |
Filter by location.home_port.node.name  |
location.home_port.uuid  |
string  |
query  |
False  |
Filter by location.home_port.uuid  |
location.auto_revert  |
boolean  |
query  |
False  |
Filter by location.auto_revert  |
location.node.uuid  |
string  |
query  |
False  |
Filter by location.node.uuid  |
location.node.name  |
string  |
query  |
False  |
Filter by location.node.name  |
location.is_home  |
boolean  |
query  |
False  |
Filter by location.is_home  |
ipspace.uuid  |
string  |
query  |
False  |
Filter by ipspace.uuid  |
ipspace.name  |
string  |
query  |
False  |
Filter by ipspace.name  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
services  |
string  |
query  |
False  |
Filter by services  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
records  |
array[ip_interface]  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ip": {
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
      "ipspace": {
        "name": "exchange",
      "location": {
        "failover": "string",
        "home_node": {
          "name": "node1",
        "home_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "node": {
          "name": "node1",
        "port": {
          "name": "e1b",
          "node": {
            "name": "node1"
      "name": "dataLif1",
      "scope": "string",
      "service_policy": {
        "name": "default-intercluster",
      "services": [
        "data_nfs"
      "state": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
ip_info
IP information
address  |
string  |
IPv4 or IPv6 address  |
family  |
string  |
IPv4 or IPv6  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.  |
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
home_node
_links  |
name  |
string  |
uuid  |
string  |
node
name  |
string  |
Name of node on which the port is located.  |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links  |
name  |
string  |
node  |
uuid  |
string  |
node
_links  |
name  |
string  |
uuid  |
string  |
port
_links  |
name  |
string  |
node  |
uuid  |
string  |
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node.
auto_revert  |
boolean  |
failover  |
string  |
Defines where an interface may failover.  |
home_node  |
home_port  |
Port UUID along with readable names. Either the UUID or both names may be supplied on input.  |
is_home  |
boolean  |
node  |
port  |
service_policy
_links  |
name  |
string  |
uuid  |
string  |
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
ip_interface
_links  |
enabled  |
boolean  |
The administrative state of the interface.  |
ip  |
IP information  |
ipspace  |
Either the UUID or name must be supplied on POST for cluster-scoped objects.  |
location  |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node.  |
name  |
string  |
Interface name  |
scope  |
string  |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".  |
service_policy  |
services  |
array[string]  |
The services associated with the interface.  |
state  |
string  |
The operational state of the interface.  |
svm  |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
vip  |
boolean  |
True for a VIP interface, whose location is announced via BGP.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
