Retrieve details for an IP route
GET /network/ip/routes/{uuid}
Retrieves the details of a specific IP route.
Related ONTAP commands
network route show
Learn more
uuid |
string |
path |
True |
Route UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
The UUID that uniquely identifies the route. |
"href": "/api/resourcelink"
"destination": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"gateway": "10.1.1.1",
"ipspace": {
"name": "exchange",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
