Retrieve IPspaces for a cluster
GET /network/ipspaces
Retrieves a collection of IPspaces for the entire cluster.
Related ONTAP commands
network ipspace show
Learn more
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[ipspace] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"name": "ipspace1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
The UUID that uniquely identifies the IPspace. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
