Retrieves cifs home directory search paths
learn more
doc /protocols/cifs/home-directory/search-paths](#docs-nas-protocols_cifs_home-directory_search-paths)
GET /protocols/cifs/home-directory/search-paths
Retrieves CIFS home directory search paths.
Related ONTAP commands
cifs server home-directory search-path show
index |
integer |
query |
False |
Filter by index |
path |
string |
query |
False |
Filter by path |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cifs_search_path] |
"next": {
"href": "/api/resourcelink"
"records": [
"index": 0,
"path": "/HomeDirectory/EngDomain",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cifs_search_path
This is a list of CIFS home directory search paths. When a CIFS client connects to a home directory share, these paths are searched in the order indicated by the position field to find the home directory of the connected CIFS client.
index |
integer |
The position in the list of paths that is searched to find the home directory of the CIFS client. Not available in POST. |
path |
string |
The file system path that is searched to find the home directory of the CIFS client. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
