REST API reference
Retrieve the NDMP node configurations for all nodes
GET /protocols/ndmp/nodes
Retrieves NDMP node configurations for all of the nodes.
  • system services ndmp show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
authentication_types
string
query
False
Filter by authentication_types
user
string
query
False
Filter by user
enabled
boolean
query
False
Filter by enabled
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[ndmp_node]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "authentication_types": [
        "plaintext",
        "challenge"
      "enabled": 1,
      "node": {
        "name": "node1",
      "user": "ndmp_user"
Status: Default
ONTAP Error Response codes
Error code Description
68812801
Node-scoped operations are not allowed in an SVM-scope.
68812804
Failed to get the node name from the specified node UUID.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
Storage system node
_links
_links
name
string
uuid
string
ndmp_node
_links
_links
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled?
node
node
Storage system node
user
string
NDMP user ID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
