REST API reference
Retrieves a kerberos realm
  • [doc /protocols/nfs/kerberos/realms](#docs-nas-protocols_nfs_kerberos_realms)
GET /protocols/nfs/kerberos/realms/{svm.uuid}/{name}
Retrieves a Kerberos realm.
  • vserver nfs kerberos realm show
svm.uuid
string
path
True
SVM UUID
name
string
path
True
Kerberos realm
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
ad_server
ad_server
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
svm
svm
      "href": "/api/resourcelink"
  "ad_server": {
    "address": "1.2.3.4",
    "name": "string"
  "comment": "string",
  "encryption_types": [
    "string"
  "kdc": {
    "ip": "1.2.3.4",
    "port": 88,
    "vendor": "string"
  "name": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ad_server
address
string
Active Directory server IP address
name
string
Active Directory server name
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are suported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
