REST API reference
Retrieve NFS protocol historical performance metrics
GET /protocols/nfs/services/{svm.uuid}/metrics
Retrieves historical performance metrics for the NFS protocol of an SVM.
timestamp
string
query
False
Filter by timestamp
v3.iops.other
integer
query
False
Filter by v3.iops.other
v3.iops.write
integer
query
False
Filter by v3.iops.write
v3.iops.read
integer
query
False
Filter by v3.iops.read
v3.iops.total
integer
query
False
Filter by v3.iops.total
v3.status
string
query
False
Filter by v3.status
v3.latency.other
integer
query
False
Filter by v3.latency.other
v3.latency.write
integer
query
False
Filter by v3.latency.write
v3.latency.read
integer
query
False
Filter by v3.latency.read
v3.latency.total
integer
query
False
Filter by v3.latency.total
v3.duration
string
query
False
Filter by v3.duration
v3.throughput.read
integer
query
False
Filter by v3.throughput.read
v3.throughput.write
integer
query
False
Filter by v3.throughput.write
v3.throughput.total
integer
query
False
Filter by v3.throughput.total
return_timeout
integer
query
False
  • Default value: 15
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
  • Default value: 1
svm.uuid
string
path
True
Unique identifier of the SVM.
interval
string
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "v3": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 UTC"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
records
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
