Retrieve NFS configuration for SVMs
GET /protocols/nfs/services
Retrieves the NFS configuration of SVMs.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver nfs show -
vserver nfs status
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
enabled |
boolean |
query |
False |
Filter by enabled |
statistics.v3.status |
string |
query |
False |
Filter by statistics.v3.status |
statistics.v3.latency_raw.other |
integer |
query |
False |
Filter by statistics.v3.latency_raw.other |
statistics.v3.latency_raw.write |
integer |
query |
False |
Filter by statistics.v3.latency_raw.write |
statistics.v3.latency_raw.read |
integer |
query |
False |
Filter by statistics.v3.latency_raw.read |
statistics.v3.latency_raw.total |
integer |
query |
False |
Filter by statistics.v3.latency_raw.total |
statistics.v3.timestamp |
string |
query |
False |
Filter by statistics.v3.timestamp |
statistics.v3.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.read |
statistics.v3.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.write |
statistics.v3.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.total |
statistics.v3.iops_raw.other |
integer |
query |
False |
Filter by statistics.v3.iops_raw.other |
statistics.v3.iops_raw.write |
integer |
query |
False |
Filter by statistics.v3.iops_raw.write |
statistics.v3.iops_raw.read |
integer |
query |
False |
Filter by statistics.v3.iops_raw.read |
statistics.v3.iops_raw.total |
integer |
query |
False |
Filter by statistics.v3.iops_raw.total |
metric.v3.duration |
string |
query |
False |
Filter by metric.v3.duration |
metric.v3.latency.other |
integer |
query |
False |
Filter by metric.v3.latency.other |
metric.v3.latency.write |
integer |
query |
False |
Filter by metric.v3.latency.write |
metric.v3.latency.read |
integer |
query |
False |
Filter by metric.v3.latency.read |
metric.v3.latency.total |
integer |
query |
False |
Filter by metric.v3.latency.total |
metric.v3.throughput.read |
integer |
query |
False |
Filter by metric.v3.throughput.read |
metric.v3.throughput.write |
integer |
query |
False |
Filter by metric.v3.throughput.write |
metric.v3.throughput.total |
integer |
query |
False |
Filter by metric.v3.throughput.total |
metric.v3.timestamp |
string |
query |
False |
Filter by metric.v3.timestamp |
metric.v3.iops.other |
integer |
query |
False |
Filter by metric.v3.iops.other |
metric.v3.iops.write |
integer |
query |
False |
Filter by metric.v3.iops.write |
metric.v3.iops.read |
integer |
query |
False |
Filter by metric.v3.iops.read |
metric.v3.iops.total |
integer |
query |
False |
Filter by metric.v3.iops.total |
metric.v3.status |
string |
query |
False |
Filter by metric.v3.status |
state |
string |
query |
False |
Filter by state |
transport.tcp_enabled |
boolean |
query |
False |
Filter by transport.tcp_enabled |
transport.udp_enabled |
boolean |
query |
False |
Filter by transport.udp_enabled |
vstorage_enabled |
boolean |
query |
False |
Filter by vstorage_enabled |
protocol.v40_enabled |
boolean |
query |
False |
Filter by protocol.v40_enabled |
protocol.v40_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.acl_enabled |
protocol.v40_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.read_delegation_enabled |
protocol.v40_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.write_delegation_enabled |
protocol.v41_enabled |
boolean |
query |
False |
Filter by protocol.v41_enabled |
protocol.v4_id_domain |
string |
query |
False |
Filter by protocol.v4_id_domain |
protocol.v41_features.pnfs_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.pnfs_enabled |
protocol.v41_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.read_delegation_enabled |
protocol.v41_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.write_delegation_enabled |
protocol.v41_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.acl_enabled |
protocol.v3_enabled |
boolean |
query |
False |
Filter by protocol.v3_enabled |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"metric": {
"v3": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 UTC"
"protocol": {
"v4_id_domain": "string"
"state": "string",
"statistics": {
"v3": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
v3
The NFSv3 operations
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
The NFSv3 operations |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 ACLs is enabled. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.1 Write Delegation is enabled. |
protocol
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 protocol is enabled. |
v41_features |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
v3
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
transport
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
nfs_service
_links |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
metric |
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
protocol |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
statistics |
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether VMware vstorage feature is enabled. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
