Retrieve FC protocol services
GET /protocols/san/fcp/services
Retrieves FC Protocol services.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
vserver fcp show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
target.name |
string |
query |
False |
Filter by target.name |
enabled |
boolean |
query |
False |
Filter by enabled |
statistics.status |
string |
query |
False |
Filter by statistics.status |
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other |
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write |
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read |
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total |
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp |
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read |
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write |
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total |
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other |
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write |
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read |
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total |
metric.duration |
string |
query |
False |
Filter by metric.duration |
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other |
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write |
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read |
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total |
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read |
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write |
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total |
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp |
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other |
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write |
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read |
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total |
metric.status |
string |
query |
False |
Filter by metric.status |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[fcp_service] |
"next": {
"href": "/api/resourcelink"
"records": [
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 UTC"
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"target": {
"name": "20:00:00:50:56:bb:b2:4b"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
target
name |
string |
The target name of the FC Protocol service. This is generated for the SVM during POST. The FC Protocol target name is a world wide node name (WWNN). If required, the target name can be modified using the ONTAP command line.
fcp_service
A Fibre Channel (FC) Protocol service defines the properties of the FC Protocol target for an SVM. There can be at most one FC Protocol service for an SVM. An SVM's FC Protocol service must be created before FC Protocol initiators can login to the SVM.
A FC Protocol service is identified by the UUID of its SVM.
_links |
enabled |
boolean |
The administrative state of the FC Protocol service. The FC Protocol service can be disabled to block all FC Protocol connectivity to the SVM. This is optional in POST and PATCH. The default setting is true (enabled) in POST. |
metric |
statistics |
svm |
target |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
