REST API reference
Retrieves an initiator of an initiator group
learn more
  • [doc /protocols/san/igroups](#docs-san-protocols_san_igroups)
GET /protocols/san/igroups/{igroup.uuid}/initiators/{name}
Retrieves an initiator of an initiator group.
  • lun igroup show
igroup.uuid
string
path
True
The unique identifier of the initiator group.
name
string
path
True
Initiator name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroup
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consist of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
      "href": "/api/resourcelink"
  "igroup": {
  "name": "iqn.1998-01.com.corp.iscsi:name1"
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The initiator is not a member of the initiator group.
5374852
The initiator group specified in the URI does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
igroup
_links
_links
uuid
string
records
_links
_links
igroup
igroup
name
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
