Retrieve a specific user account
GET /security/accounts/{owner.uuid}/{name}
Retrieves a specific user account.
Related ONTAP commands
security login show
fields |
array[string] |
query |
False |
owner.uuid |
string |
path |
True |
Account owner UUID |
name |
string |
path |
True |
User account name |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[account] |
"next": {
"href": "/api/resourcelink"
"records": [
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"name": "joe.smith",
"owner": {
"name": "svm1",
"password": "string",
"role": {
"name": "admin"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_application
application |
string |
Applications |
authentication_methods |
array[string] |
second_authentication_method |
string |
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications. |
owner
Owner name and UUID that uniquely identifies the user account.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
role
_links |
name |
string |
Role name |
account
_links |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
locked |
boolean |
Locked status of the account. |
name |
string |
User or group account name |
owner |
Owner name and UUID that uniquely identifies the user account. |
password |
string |
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters. |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
