Retrieve the administrative audit log viewer
GET /security/audit/messages
Retrieves the administrative audit log viewer.
Learn more
index |
integer |
query |
False |
Filter by index |
timestamp |
string |
query |
False |
Filter by timestamp |
state |
string |
query |
False |
Filter by state |
scope |
string |
query |
False |
Filter by scope |
application |
string |
query |
False |
Filter by application |
user |
string |
query |
False |
Filter by user |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
location |
string |
query |
False |
Filter by location |
session_id |
string |
query |
False |
Filter by session_id |
command_id |
string |
query |
False |
Filter by command_id |
message |
string |
query |
False |
Filter by message |
input |
string |
query |
False |
Filter by input |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[security_audit_log] |
"next": {
"href": "/api/resourcelink"
"records": [
"application": "string",
"command_id": "string",
"index": 0,
"input": "string",
"location": "string",
"message": "string",
"node": {
"name": "node1",
"scope": "string",
"session_id": "string",
"state": "string",
"svm": {
"name": "string"
"timestamp": "string",
"user": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
Node where the audit message resides.
_links |
name |
string |
uuid |
string |
svm
This is the SVM through which the user connected.
name |
string |
security_audit_log
_links |
application |
string |
This identifies the "application" by which the request was processed. |
command_id |
string |
This is the command ID for this request. Each command received on a CLI session is assigned a command ID. This enables you to correlate a request and response. |
index |
integer |
Internal index for accessing records with same time/node. This is a 64 bit unsigned value. |
input |
string |
The request. |
location |
string |
This identifies the location of the remote user. This is an IP address or "console". |
message |
string |
This is an optional field that might contain "error" or "additional information" about the status of a command. |
node |
Node where the audit message resides. |
scope |
string |
Set to "svm" when the request is on a data SVM; otherwise set to "cluster". |
session_id |
string |
This is the session ID on which the request is received. Each SSH session is assigned a session ID. Each http/ontapi/snmp request is assigned a unique session ID. |
state |
string |
State of of this request. |
svm |
This is the SVM through which the user connected. |
timestamp |
string |
Log entry timestamp. Valid in URL |
user |
string |
Username of the remote user. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
