Retrieve administrative audit settings for GET requests
GET /security/audit
Retrieves administrative audit settings for GET requests.
Learn more
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
cli |
boolean |
Enable auditing of CLI GET Operations. Valid in PATCH |
http |
boolean |
Enable auditing of HTTP GET Operations. Valid in PATCH |
ontapi |
boolean |
Enable auditing of ONTAP API GET operations. Valid in PATCH |
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
