Retrieve AKVs configured for all clusters and SVMs
GET /security/azure-key-vaults
Retrieves AKVs configured for all clusters and SVMs.
Related ONTAP commands
security key-manager external azure show
Learn more
key_id |
string |
query |
False |
Filter by key_id |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
client_id |
string |
query |
False |
Filter by client_id |
tenant_id |
string |
query |
False |
Filter by tenant_id |
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
state.message |
string |
query |
False |
Filter by state.message |
state.cluster_state |
boolean |
query |
False |
Filter by state.cluster_state |
state.code |
integer |
query |
False |
Filter by state.code |
scope |
string |
query |
False |
Filter by scope |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[azure_key_vault] |
"next": {
"href": "/api/resourcelink"
"records": [
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"key_id": "https://keyvault1.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"scope": "string",
"state": {
"code": 346758,
"message": "AKV key protection is unavailable in following nodes - node1, node2."
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
state
Indicates whether the AKV key protection is available cluster wide.
cluster_state |
boolean |
Set to true when AKV key protection is available on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV key protection is available in all nodes of the cluster. |
message |
string |
Error message set when cluster availability is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
azure_key_vault
_links |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that will be used by ONTAP for storing keys.
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Indicates whether the AKV key protection is available cluster wide. |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
