Retrieve key servers configured in an external key manager
GET /security/key-managers/{uuid}/key-servers/{server}
Retrieves key servers configured in an external key manager.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
connectivity
Related ONTAP commands
security key-manager external show -
security key-manager external show-status
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Key server configured in the key manager. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
connectivity |
This property returns the key server connectivity state on all nodes of the cluster. The state is returned for a node only if the connectivity is not in an available state on that node.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
"href": "/api/resourcelink"
"connectivity": {
"records": [
"node": {
"name": "node1",
"state": "not_responding"
"password": "password",
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability |
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
records |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
_links |
connectivity |
password |
string |
server |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
