Retrieve login banner and messages of the day
GET /security/login/messages
Retrieves the login banner and messages of the day (MOTD) configured in the cluster and in specific SVMs.
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
show_cluster_message |
boolean |
query |
False |
Filter by show_cluster_message |
banner |
string |
query |
False |
Filter by banner |
message |
string |
query |
False |
Filter by message |
scope |
string |
query |
False |
Filter by scope |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[login_messages] |
"next": {
"href": "/api/resourcelink"
"records": [
"banner": "string",
"message": "string",
"scope": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
login_messages
The login banner and message of the day (MOTD) configuration.
_links |
banner |
string |
The login banner text. This message is displayed during SSH and console device login just before the password prompt displays. When configured, a cluster-level login banner is used for every incoming connection. Each data SVM can override the cluster-level banner to instead display when you log into the SVM. To restore the default setting for a data SVM, set the banner to an empty string. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body. |
message |
string |
The message of the day (MOTD). This message appears just before the clustershell prompt after a successful login. When configured, the cluster message displays first. If you log in as a data SVM administrator, the SVM message is then printed. The cluster-level MOTD can be disabled for a given data SVM using the "show_cluster_message" property. New lines are supplied as either LF or CRLF but are always returned as LF. Optional in the PATCH body. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
boolean |
Specifies whether to show a cluster-level message before the SVM message when logging in as an SVM administrator. This setting can only be modified by the cluster administrator. Optional in the PATCH body. |
svm |
uuid |
string |
The unique identifier (ID) of the login messages configuration. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
