Retrieve the access level for a REST API path or command/command directory path for a role
GET /security/roles/{owner.uuid}/{name}/privileges/{path}
Retrieves the privilege level for a REST API path for the specified role.
Related ONTAP commands
security login rest-role show
fields |
array[string] |
query |
False |
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
path |
string |
path |
True |
REST API path |
Status: 200, Ok
| Name | Type | Description |
_links |
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
"href": "/api/resourcelink"
"access": "readonly",
"path": "/api/storage/volumes"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
