Retrieve privilege details of the specified role
GET /security/roles/{owner.uuid}/{name}/privileges
Retrieves privilege details of the specified role.
Related ONTAP commands
security login rest-role show
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[role_privilege] |
"next": {
"href": "/api/resourcelink"
"records": [
"access": "readonly",
"path": "/api/storage/volumes"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links |
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
