Retrieve the details of a role
GET /security/roles/{owner.uuid}/{name}
Retrieves the details of the specified role.
Related ONTAP commands
security login rest-role show
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
owner.uuid  |
string  |
path  |
True  |
Role owner UUID  |
name  |
string  |
path  |
True  |
Role name  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[role]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "name": "admin",
      "owner": {
        "name": "svm1",
      "privileges": [
          "access": "readonly",
          "path": "/api/storage/volumes"
      "scope": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
owner
Owner name and UUID that uniquely identifies the role.
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links  |
access  |
string  |
Access level for the REST endpoint.  |
path  |
string  |
REST URI/endpoint  |
role
A named set of privileges that defines the rights an account has when it is assigned the role.
_links  |
builtin  |
boolean  |
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.  |
name  |
string  |
Role name  |
owner  |
Owner name and UUID that uniquely identifies the role.  |
privileges  |
array[role_privilege]  |
The list of privileges that this role has been granted.  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
