Retrieve an aggregate specified by the UUID
GET /storage/aggregates/{uuid}
Retrieves the aggregate specified by the UUID. The recommend query cannot be used for this operation.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
metrics.* -
space.block_storage.inactive_user_data -
space.footprint -
statistics.*
Related ONTAP commands
storage aggregate show
Learn more
uuid |
string |
path |
True |
Aggregate UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier. |
create_time |
string |
Timestamp of aggregate creation |
data_encryption |
dr_home_node |
Node where the aggregate belongs after disaster recovery. The value for this field might differ from the 'node' field during switchover. |
home_node |
Node where the aggregate belongs after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
metric |
The most recent sample of I/O metrics for the aggregate. |
name |
string |
Aggregate name |
node |
Node where the aggregate currently resides. |
snaplock_type |
string |
SnapLock type |
space |
state |
string |
Operational state of the aggregate |
statistics |
The real time I/O statistics for the aggregate. |
uuid |
string |
Aggregate UUID |
"href": "/api/resourcelink"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_type": "string",
"size": 1612709888,
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"checksum_style": "string",
"disk_class": "performance",
"disk_count": 8,
"disk_type": "fc",
"raid_size": 16,
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"create_time": "2018-01-01 12:00:00 -0400",
"dr_home_node": {
"name": "node1",
"home_node": {
"name": "node1",
"metric": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 UTC"
"name": "node1_aggr_1",
"node": {
"name": "node1",
"snaplock_type": "string",
"space": {
"block_storage": {
"available": 10156560384,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"size": 10156769280,
"used": 2088960
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896
"state": "string",
"statistics": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787092 |
The target field cannot be specified for this operation. |
8586225 |
Encountered unexpected error in retrieving metrics and statistics for an aggregate. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
enabled |
boolean |
Aggregate uses HDDs with SSDs as a cache |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
_links |
name |
string |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style |
string |
The checksum style used by the aggregate. |
disk_class |
string |
The class of disks being used by the aggregate. |
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
disk_type |
enum |
The type of disk being used by the aggregate. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
RAID type of the aggregate. |
block_storage
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
cloud_store
Cloud store
_links |
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
attach_eligible |
boolean |
Aggregate is eligible for a cloud store to be attached. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
drive_protection_enabled |
boolean |
Aggregate uses self-encrypting drives with data protection enabled. |
software_encryption_enabled |
boolean |
NetApp Aggregate Encryption enabled. All data in the aggregate is encrypted. |
dr_home_node
name |
string |
uuid |
string |
home_node
_links |
name |
string |
uuid |
string |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node
_links |
name |
string |
uuid |
string |
block_storage
available |
integer |
Space available in bytes |
full_threshold_percent |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
inactive_user_data |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregate with a cloud store tier. |
efficiency
Storage efficiency
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
Storage efficiency that does not include the savings provided by Snapshot copies
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
space
block_storage |
cloud_storage |
efficiency |
Storage efficiency |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
