Retrieve attributes of the FlexCache volume in the cluster
GET /storage/flexcache/flexcaches/{uuid}
Retrieves attributes of the FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are included by default in GET. The recommended method to use this API is to filter and retrieve only the required fields. See DOC Requesting specific fields to learn more.
origins.ip_address- IP address of origin. -
origins.size- Physical size of origin. -
origins.state- State of origin. -
size- Physical size of FlexCache. -
guarantee.type- Space guarantee style of FlexCache. -
aggregates.nameoraggregates.uuid- Name or UUID of aggregrate of FlexCache volume. -
path- Fully-qualified path of the owning SVM's namespace where the FlexCache is mounted.
Related ONTAP commands
volume flexcache show
Learn more
uuid |
string |
path |
True |
Unique identifier of FlexCache. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
aggregates |
array[aggregates] |
constituents_per_aggregate |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
guarantee |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
"href": "/api/resourcelink"
"aggregates": [
"name": "aggr1",
"guarantee": {
"type": "string"
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 19:00:00 UTC",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
guarantee
type |
string |
The type of space guarantee of this volume in the aggregate. |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
