Retrieve the origin of a FlexCache volume in the cluster
GET /storage/flexcache/origins
Retrieves origin of FlexCache in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
flexcaches.ip_address- IP address of FlexCache. -
flexcaches.size- Physical size of FlexCache. -
flexcaches.guarantee.type- Space guarantee style of FlexCache. -
flexcaches.state- State of FlexCache.
Related ONTAP commands
volume flexcache origin show-caches
Learn more
uuid |
string |
query |
False |
Filter by uuid |
flexcaches.svm.uuid |
string |
query |
False |
Filter by flexcaches.svm.uuid |
flexcaches.svm.name |
string |
query |
False |
Filter by flexcaches.svm.name |
flexcaches.size |
integer |
query |
False |
Filter by flexcaches.size |
flexcaches.ip_address |
string |
query |
False |
Filter by flexcaches.ip_address |
flexcaches.volume.uuid |
string |
query |
False |
Filter by flexcaches.volume.uuid |
flexcaches.volume.name |
string |
query |
False |
Filter by flexcaches.volume.name |
flexcaches.create_time |
string |
query |
False |
Filter by flexcaches.create_time |
flexcaches.state |
string |
query |
False |
Filter by flexcaches.state |
flexcaches.cluster.name |
string |
query |
False |
Filter by flexcaches.cluster.name |
flexcaches.cluster.uuid |
string |
query |
False |
Filter by flexcaches.cluster.uuid |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[flexcache_origin] |
"next": {
"href": "/api/resourcelink"
"records": [
"flexcaches": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 19:00:00 UTC",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"name": "vol1, vol_2",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
Origin volume SVM
_links |
name |
string |
uuid |
string |
flexcache_origin
Defines the origin endpoint of FlexCache.
_links |
flexcaches |
array[flexcache_relationship] |
name |
string |
Origin volume name |
svm |
Origin volume SVM |
uuid |
string |
Origin volume UUID. Unique identifier for origin of FlexCache. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
