REST API reference
Retrieves a collection of qos policies
GET /storage/qos/policies
Retrieves a collection of QoS policies.
fixed.min_throughput_iops
integer
query
False
Filter by fixed.min_throughput_iops
fixed.max_throughput_iops
integer
query
False
Filter by fixed.max_throughput_iops
fixed.capacity_shared
boolean
query
False
Filter by fixed.capacity_shared
fixed.max_throughput_mbps
integer
query
False
Filter by fixed.max_throughput_mbps
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
adaptive.peak_iops
integer
query
False
Filter by adaptive.peak_iops
adaptive.expected_iops
integer
query
False
Filter by adaptive.expected_iops
adaptive.absolute_min_iops
integer
query
False
Filter by adaptive.absolute_min_iops
object_count
integer
query
False
Filter by object_count
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[qos_policy]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "records": [
      "name": "extreme",
      "object_count": 0,
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
self
adaptive
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space.
absolute_min_iops
integer
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
expected_iops
integer
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
peak_iops
integer
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size.
fixed
QoS policy-groups define a fixed service level objective (SLO) for a storage object.
capacity_shared
boolean
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false.
max_throughput_iops
integer
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced.
max_throughput_mbps
integer
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced.
min_throughput_iops
integer
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
qos_policy
_links
_links
adaptive
adaptive
fixed
fixed
name
string
Name of the QoS policy.
object_count
integer
Number of objects attached to this policy.
svm
svm
uuid
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
