Retrieve shelves
GET /storage/shelves
Retrieves a collection of shelves.
Related ONTAP commands
storage shelf show -
storage shelf port show -
storage shelf drawer show
Learn more
uid |
string |
query |
False |
Filter by uid |
connection_type |
string |
query |
False |
Filter by connection_type |
drawers.id |
integer |
query |
False |
Filter by drawers.id |
drawers.serial_number |
string |
query |
False |
Filter by drawers.serial_number |
drawers.part_number |
string |
query |
False |
Filter by drawers.part_number |
drawers.error |
string |
query |
False |
Filter by drawers.error |
drawers.closed |
boolean |
query |
False |
Filter by drawers.closed |
drawers.state |
string |
query |
False |
Filter by drawers.state |
drawers.disk_count |
integer |
query |
False |
Filter by drawers.disk_count |
module_type |
string |
query |
False |
Filter by module_type |
bays.state |
string |
query |
False |
Filter by bays.state |
bays.has_disk |
boolean |
query |
False |
Filter by bays.has_disk |
bays.type |
string |
query |
False |
Filter by bays.type |
bays.id |
integer |
query |
False |
Filter by bays.id |
model |
string |
query |
False |
Filter by model |
serial_number |
string |
query |
False |
Filter by serial_number |
state |
string |
query |
False |
Filter by state |
disk_count |
integer |
query |
False |
Filter by disk_count |
frus.state |
string |
query |
False |
Filter by frus.state |
frus.part_number |
string |
query |
False |
Filter by frus.part_number |
frus.firmware_version |
string |
query |
False |
Filter by frus.firmware_version |
frus.type |
string |
query |
False |
Filter by frus.type |
frus.serial_number |
string |
query |
False |
Filter by frus.serial_number |
frus.id |
integer |
query |
False |
Filter by frus.id |
ports.module_id |
string |
query |
False |
Filter by ports.module_id |
ports.wwn |
string |
query |
False |
Filter by ports.wwn |
ports.cable.identifier |
string |
query |
False |
Filter by ports.cable.identifier |
ports.cable.length |
string |
query |
False |
Filter by ports.cable.length |
ports.cable.part_number |
string |
query |
False |
Filter by ports.cable.part_number |
ports.cable.serial_number |
string |
query |
False |
Filter by ports.cable.serial_number |
ports.state |
string |
query |
False |
Filter by ports.state |
ports.remote.phy |
string |
query |
False |
Filter by ports.remote.phy |
ports.remote.wwn |
string |
query |
False |
Filter by ports.remote.wwn |
ports.remote.port |
string |
query |
False |
Filter by ports.remote.port |
ports.remote.mac_address |
string |
query |
False |
Filter by ports.remote.mac_address |
ports.remote.chassis |
string |
query |
False |
Filter by ports.remote.chassis |
ports.mac_address |
string |
query |
False |
Filter by ports.mac_address |
ports.internal |
boolean |
query |
False |
Filter by ports.internal |
ports.designator |
string |
query |
False |
Filter by ports.designator |
ports.id |
integer |
query |
False |
Filter by ports.id |
internal |
boolean |
query |
False |
Filter by internal |
name |
string |
query |
False |
Filter by name |
paths.name |
string |
query |
False |
Filter by paths.name |
paths.node.uuid |
string |
query |
False |
Filter by paths.node.uuid |
paths.node.name |
string |
query |
False |
Filter by paths.node.name |
id |
string |
query |
False |
Filter by id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[shelf] |
"next": {
"href": "/api/resourcelink"
"records": [
"bays": [
"id": 0,
"state": "ok",
"type": "single_disk"
"connection_type": "sas",
"disk_count": 12,
"drawers": [
"disk_count": 12,
"error": "string",
"part_number": "111-03071",
"serial_number": "021604008263",
"state": "ok"
"frus": [
"firmware_version": "0191",
"part_number": "111-00690+A2",
"serial_number": 8000166294,
"state": "error",
"type": "module"
"id": 1,
"model": "DS2246",
"module_type": "iom6",
"name": 1.1,
"paths": [
"name": "2a",
"node": {
"name": "node1",
"ports": [
"cable": {
"identifier": "500a0980000b6c3f-50000d1703544b80",
"length": "2m",
"part_number": "112-00431+A0",
"serial_number": 616930439
"designator": "square",
"id": 0,
"mac_address": "string",
"module_id": "a",
"remote": {
"chassis": "string",
"phy": 12,
"port": "string",
"wwn": "50000D1703544B80"
"state": "connected",
"wwn": "500A0980000B6C3F"
"serial_number": "SHFMS1514000895",
"state": "ok",
"uid": 7777841915827391056
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
bays
has_disk |
boolean |
id |
integer |
state |
string |
type |
string |
drawers
closed |
boolean |
disk_count |
integer |
error |
string |
id |
integer |
part_number |
string |
serial_number |
string |
state |
string |
frus
firmware_version |
string |
id |
integer |
part_number |
string |
serial_number |
string |
state |
string |
type |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
paths
Storage port
_links |
name |
string |
node |
cable
identifier |
string |
length |
string |
part_number |
string |
serial_number |
string |
remote
chassis |
string |
mac_address |
string |
phy |
string |
port |
string |
wwn |
string |
ports
cable |
designator |
string |
id |
integer |
internal |
boolean |
mac_address |
string |
module_id |
string |
remote |
state |
string |
wwn |
string |
shelf
bays |
array[bays] |
connection_type |
string |
disk_count |
integer |
drawers |
array[drawers] |
frus |
array[frus] |
id |
string |
internal |
boolean |
model |
string |
module_type |
string |
name |
string |
paths |
array[paths] |
ports |
array[ports] |
serial_number |
string |
state |
string |
uid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
