Retrieves the snaplock complianceclock for a specific node
learn more
doc /storage/snaplock/compliance-clocks](#docs-snaplock-storage_snaplock_compliance-clocks)
GET /storage/snaplock/compliance-clocks/{node.uuid}
Retrieves the SnapLock ComplianceClock for a specific node.
Related ONTAP commands
snaplock compliance-clock show
Learn more
node.uuid |
string |
path |
True |
Node UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
node |
time |
string |
Compliance clock time |
"href": "/api/resourcelink"
"node": {
"name": "node1",
"time": "2018-06-04 19:00:00 UTC"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
