Retrieve litigations under an SVM
GET /storage/snaplock/litigations
Retrieves the list of litigations under an SVM.
Related ONTAP commands
snaplock legal-hold show
Learn more
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of Records  |
records  |
array[snaplock_litigation]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "id": "string",
      "name": "lit1",
      "operations": [
          "id": 16842759,
          "num_files_failed": 0,
          "num_files_processed": 30,
          "num_files_skipped": 10,
          "num_inodes_ignored": 10,
          "path": "/dir1",
          "state": "completed",
          "type": "begin"
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346  |
Internal Error. Wait a few minutes, then try the command again  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
snaplock_legal_hold_operation
_links  |
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
Specifies the number of files on which legal-hold operation failed.  |
num_files_processed  |
string  |
Specifies the number of files on which legal-hold operation was successful.  |
num_files_skipped  |
string  |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.  |
num_inodes_ignored  |
string  |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.  |
path  |
string  |
Specifies the path on which legal-hold operation is applied.  |
state  |
string  |
Specifies the status of legal-hold operation.  |
type  |
string  |
Specifies the type of legal-hold operation.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
volume
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
snaplock_litigation
_links  |
id  |
string  |
Specifies the litigation ID.  |
name  |
string  |
Specifies the legal-hold litigation name.  |
operations  |
svm  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
