Retrieve volume Snapshot copies
GET /storage/volumes/{volume.uuid}/snapshots
Retrieves a collection of volume Snapshot copies.
Related ONTAP commands
snapshot show
Learn more
volume.uuid  |
string  |
path  |
True  |
Volume  |
volume.uuid  |
string  |
query  |
False  |
Filter by volume.uuid  |
volume.name  |
string  |
query  |
False  |
Filter by volume.name  |
name  |
string  |
query  |
False  |
Filter by name  |
create_time  |
string  |
query  |
False  |
Filter by create_time  |
comment  |
string  |
query  |
False  |
Filter by comment  |
snaplock_expiry_time  |
string  |
query  |
False  |
Filter by snaplock_expiry_time  |
expiry_time  |
string  |
query  |
False  |
Filter by expiry_time  |
state  |
string  |
query  |
False  |
Filter by state  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
snapmirror_label  |
string  |
query  |
False  |
Filter by snapmirror_label  |
owners  |
string  |
query  |
False  |
Filter by owners  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
The default is true for GET calls. When set to false, only the number of records is returned.  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[snapshot]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "create_time": "2019-02-04 19:00:00 UTC",
      "expiry_time": "2019-02-04 19:00:00 UTC",
      "name": "this_snapshot",
      "owners": [
        "string"
      "snaplock_expiry_time": "2019-02-04 19:00:00 UTC",
      "snapmirror_label": "string",
      "state": "string",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volume": {
        "name": "volume1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
volume
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
_links  |
comment  |
string  |
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.  |
create_time  |
string  |
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.  |
expiry_time  |
string  |
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.  |
name  |
string  |
Snapshot copy. Valid in POST or PATCH.  |
owners  |
array[string]  |
string  |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time.  |
snapmirror_label  |
string  |
Label for SnapMirror operations  |
state  |
string  |
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.  |
svm  |
uuid  |
string  |
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
